1. LF481Q1-1702141A Vent valve gasket
2. LF481Q1-1702151A Shift cap
3. LF481Q1-1702138A Shift shaft circlip
4. LF481Q1-1702138A Return spring seat
5. LF481Q1-1702156A Return spring
6. LF481Q1-1702035A Transposition swing arm seal
7. LF481Q1-1702115A Transposition swing level bolt
8. LF481Q1-1702030A Transposition swing arm
9. LF481Q1-1702142A Shift swinglever
10. LF481Q1-1702116A Pin
11. LF481Q1-1702155A Return spring
12. LF481Q1-1702154A Shift shaft washer
13. LF481Q1-1702137A Shift shaft circlip
14. LF481Q1-1702108A Shift swinglever interlock bracket
15. LF481Q1-1702120A Fifth reverse cam
16. LF481Q1-1702122A Fifth reverse cam spring
17. LF481Q1-1702016A Shift cap position ring
18. LF481Q1-1702121A Fifth reverse cam seal ball
19. LF481Q1-1702152A Shift cap bush
20. LF481Q1-1702036A Shift shaft seal
21. LF481Q1-1702105A Shift shaft sleeve
22. LF481Q1-1702110A Shift shaft component
23. LF481Q1-1702130A Vent valve assy
24. LF481Q1-1702114A Transposition swing lever
25. LF481Q1-1702123A Fifth reverse cam pin
26. LF481Q1-1701090A Reverse swing arm bracket
27. LF481Q1-1701085A Washer
28. LF481Q1-1701095A Bolt
Интерактивный каталог доступен по адресу autoopt.ru/auto/catalog/car/lifan/lf-7162c_solano/29/
