Тех. помощь Разблокировка магнитол Philips
В данный момент доступна разблокировка следующих магнитол:
ALFA ROMEO 22DC710/25S
AUDI BETA II
BMW 22DC785/23 BUSINESS RDS
BMW 22DC785/23B BUSINESS RDS
BMW 22DC785/23E BUSINESS RDS
BMW 22DC785/23F BUSINESS RDS
BMW 22DC785/24 BUSINESS RDS
BMW 22DC785/24E BUSINESS RDS
BMW 22DC785/24F BUSINESS RDS
BMW 22DC785/24S BUSINESS RDS
BMW 22DC785/24Z BUSINESS RDS
BMW 22DC785/33B BUSINESS RDS
BMW 22DC785/33F BUSINESS RDS
BMW 22DC785/33L BUSINESS RDS
CITROEN 22DC594/35
CITROEN 22DC720/35
CITROEN 22RC200/35
CITROEN 22RC200/35
CITROEN 22RC220/35
CITROEN 22RC220/35Z
CITROEN 22RC465/35
CITROEN 22RC465/35S
CITROEN 22RC465/65
FIAT 22DC349/64
FIAT 22DC449/64L
FIAT 22DC449/64S
FIAT 22DC710/64S
FIAT 22DC731/64
FIAT 22RC465/65
FORD 22DC600/70
FORD DC666/70Z
HONDA 22DC681/02
LANCIA 22DC710/65L
LANCIA 22RC465/65
LAND ROVER 22DC651/61
LAND ROVER 22DC711/61
OPEL 22DC247/78
OPEL 22DC347/78
OPEL 22DC670
OPEL 22DC670/60F
OPEL 22DC670/78
OPEL 22DC681
OPEL 22DC682
OPEL 22DC684
OPEL 22DC685/78
OPEL 22DC720/78
OPEL CAR2004
OPEL CAR400
OPEL CCR2006(E) 2DIN 09 146 057
OPEL CCR600
OPEL CCR800 BOSE
OPEL CCRT2008
OPEL CCRT700/GSM
OPEL S200 DN460/75
OPEL SC201
OPEL SC201D
OPEL SC804
OPEL SC804D
PEUGEOT 22DC594/65
PEUGEOT 22DC710/65
PEUGEOT 22DC722/65
PEUGEOT 22RC200/65 96 392 193 80 02
22DC343/00
22DC347/62
22DC397/75
22DC401
22DC405/00
22DC415/02
22DC415/52
22DC415/94
22DC460/75
22DC501/00
22DC501/74
22DC505/02
22DC505/82
22DC506/02
22DC511/00
22DC511/02
22DC515/02
22DC570
22DC570/60
22DC575/02
22DC575/52
22DC666/78
22DC670/00
22DC675/02
22DC675/52
22DC680/00
22DC680/50
22DC681/00
22DC681/50
22DC681/685 RG681W
22DC682/00
22DC682/30
22DC682/78
22DC682/82
22DC684/52
22DC684/78
22DC684/82
22DC685/02
22DC685/62
22DC695/32
22DC701/00
22DC701/80
22DC711/00
22DC711/78
22DC711/80
22DC720/00
22DC722/00
22DC730/00
22DC731/00
22DC740/30
22DC741/00
22DC764/02
22DC774/02
22DC777
22DC794
22DC924/02R Tuner CD
22DC964/02R Tuner CD
22DC964/52R Tuner CD
22DC983/02R
90 DC401/00
90 DC411/00R
90 DC411/80
90 DC415/82
RENAULT 22DC100/00
RENAULT 22DC229/62
RENAULT 22DC239/62
RENAULT 22DC257/62
RENAULT 22DC258/62
RENAULT 22DC259/62
RENAULT 22DC269/62
RENAULT 22DC277/62
RENAULT 22DC278/62
RENAULT 22DC279/62
RENAULT 22DC280/62
RENAULT 22DC347/62
RENAULT 22DC379/62
RENAULT 22DC449/62
RENAULT 22DC451/62
RENAULT 22DC459/62
RENAULT 22DC459/72
RENAULT 22DC461/62
RENAULT 22DC461/72
RENAULT 22DC479/62
RENAULT 22DC481/62
RENAULT 22DC501/62
RENAULT 22DC577/62
RENAULT 22DC579/62
RENAULT 22DC593/62
RENAULT 22DC594/62
RENAULT 22DC661/62
RENAULT 22DC665/62
RENAULT 22DC677/62
RENAULT 22DC679/62
RENAULT 22DC679/72
RENAULT 22DC711/62
RENAULT 22DC882/62
RENAULT 22DC882/72
RENAULT 22DC885/62
RENAULT 22DC942/62
RENAULT 22DC962/62
RENAULT 22DC982/62
RENAULT 22DC982/72
ROVER 22DC349/60 R660
ROVER 22DC594/60E R760
ROVER 22DC652/60
ROVER 22DC670/60 RG670W
ROVER 22DC681/60 R681
ROVER 22DC710/60
ROVER 22DC710/61L
ROVER 22DC711/60E
ROVER 22DC741/60E
ROVER 22DC745/60
ROVER 22DC984/60
SAAB 22DC720/30R
SUBARU 22DC685/92
TOYOTA 22DC343/74
VOLVO VC-601 22DC652/77
VOLVO VC-602 22DC511/77
VOLVO VC-608 22DC670/77
VOLVO VC-708 22DC680/77
VOLVO VC-802 22DC711/77
VW ALPHA IV DC587/71
VW BETA V DC589/71
VW GAMMA 3 DC586/71
VW GAMMA IV DC588/71
Как разблокировать магнитолу Philips, если утерян код? В данной теме помогу определить код магнитолы данного производителя.
Магнитолы Philips устанавливались на автомобили марок BMW, Citroen, Fiat, Opel, Rover, Renaut, Volvo, VW.
Для получения кода магнитолу необходимо снять, переписать с нее серийный номер, выглядит примерно так:
PH7850T1127292
Либо выложить фото наклейки.
помоги с кодом
Помогите с кодом
Магнитола Philips
    576,9 КБ · Просмотры: 48
добрый день подскажите почему магнитола постоянно требует пароль при заводе и при каждом включенити CCRT 2008
Добрый день! Помогите пожалуйста с кодом на магнитолу CCR2006(e)
    263,6 КБ · Просмотры: 9
@alibaba, можете посмотреть
    56,4 КБ · Просмотры: 18
Добрый день. Помогите пожалуйста с разблокировкой магнитолы Philips Car 400
    412,2 КБ · Просмотры: 7
Доброго времени суток... Ввожу код магнитолы, но пишет что неверно и заново требует код... В чем может быть проблема?!
Кто читает эту тему (всего читателей: 3)
  1. @ kostel87:
  2. @ Маэстро:
    Маэстро, Скорее всего, проблема не в самом доводчике, а в цепи питания электропривода двери. На Freed доводчик и электропривод могут питаться через разные цепи: среди основных проверяемых элементов указаны предохранитель RR DOOR, реле питания, реле управления, замок с электроприводом и жгут проводов. Я бы проверял по порядку: Предохранитель RR DOOR - не только визуально, а контролькой или мультиметром с включённым зажиганием. Важно проверить наличие напряжения на обоих выводах предохранителя. Контакты и посадочное место предохранителя. Бывает окисление или плохой контакт в блоке: после извлечения и установки предохранителя дверь у некоторых владельцев временно начинала работать. Реле электродвери и реле управления. Если на предохранителе нет питания, нужно идти назад по цепи - к реле и его управляющему сигналу. Жгут проводов в районе сдвижной двери и кузовной стойки. Перелом жилы или окисление фишки может отключить привод, при этом доводчик останется рабочим. Концевики, замок и защита от защемления. Если блок видит неправильное положение двери, сопротивление движению или неисправный датчик, он может запретить работу электропривода. Выключатель электропривода на панели и закрытие лючка бензобака. При открытом лючке система может блокировать или ограничивать работу двери. Если доводчик срабатывает, замок защёлкивается, но дверь не едет ни с кнопки, ни с ручки, стоит считать ошибки диагностикой. На похожем случае у Freed появлялась ошибка B2042 - потеря связи с дверью или её блоком управления; после сброса ошибка временно исчезала, но затем возвращалась. Можно попробовать простой сброс: снять минусовую клемму аккумулятора на несколько минут, затем подключить обратно. Иногда после срабатывания защиты или сбоя блока дверь оживает, но если неисправность физическая, это будет только временная мера. Проверять мотор, замок или привод напрямую от аккумулятора без понимания распиновки не советую - можно получить не диагностику, а дополнительный ремонт. Начните с измерения: есть ли питание на предохранителе, приходит ли оно на разъём привода и меняется ли состояние управляющих проводов при нажатии кнопки. Если на предохранителе питания нет, сразу ищите реле, блок управления и обрыв до него, а не меняйте доводчик наугад.
